Golden Intersar Receivers Aes problems
Y
yano65
Likes
Golden Interstar 8005 ci PREMIUM CLASS
Morocco
#1
Hello !
Well ,i 'd like to know why Golden Intersar Receivers don't accept updating Aes Keys by Remote Control.
Is there any Trick for this.
As i know for others receivers is possible to do that.
Thanks.
B
brewby
Likes
The software does not accept aes keys by remote, you need a little prog called STBuUtil which opens the software file and allows you change the aes key, save and then upload to your reciever. be careful not to change anything in the main program as this will screw it up if you don't know what you are doing. You can also change the keys in the cas section.
You can find what you need at satexperts (google it) you will need to register (it's turkish I think) but they do have an English section.
Y
yano65
Likes
Morocco
#3
Hello !
Thanks+++++:-Cbigsmil
i will go to the site recommended by you. :)
bye.
