Greenpeace hacks Astra satellite
oneill
Visit site
Denmark
Weird stuff ... my reception has been pixily the last few days, ITV dropping out occasionally for hours at a time. Today when I turned on the telly - all satellite channels have turned green !!!! Seriously - reception appears okay, no pixilation, but everything is shades of green, only satelitte channels though, not terrestial channels ! Any suggestions ?
Also a tech question - is there any serious benefit to buying a 1.2m off-set dish as opposed to my present 1.2m pure-parabolic dish with center fitted LNB ?? Are we talking real or theoretical benefits ?
Soren in Denmark
oneill AT c DOT dk
Sounds like a scart problem oneill, I presume that you are running on RGB?
Can't answer the dish question as i don't have the experience of both types.
Zorba
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
If not a scart problem,then just power off the digibox for 5minutes.As for the pixellation problem,check dish alignment and connectors at both ends of cable.
oneill
Visit site
Denmark
I dont think it is ... see the digibox menues, programlisting etc is all the usual blue and white (Grundig GSD300), its only the actual TV-picture which is green ...
Zorba
Did you power off and on?
oneill
Visit site
Denmark
Yep ... just did ... it worked ... weird though aint it ?
Any ideas about the parabolic vs. the off-set dish ?
Zorba
these old grundigs get stressed easily,they need to cool off now and again.your power supply is probably on the way out,a common problem.
As for the dishes,not much difference I think except that as the round dish tilts back more,then when it snows it will settle on that dish and block the signal.
>COR<
Sneek, HOLLAND
The Gain of an offset dish over the prime focus deminishes around the 1 metre range, both are equal at 1.20.
After that the prime focus is the same/better.
The advantage of the offset is that it's almost vertical and using carwax, snow and stuff doesn't stick :D
Cheers,
Cor.
