grr stupid motor
Yeshi
Norden - Near Edenfield (not Rochdale)
Dm500, TM9100, Samsung V+, 1M Dish. Motect 2100..
37Inch Plasma, Wii, Xbox360.
Behind pin 9 on an atmel
Getting really frustrated here :@
Anyway my motor is playing up.. moteck 2100..
Anyway i can move the motor manualy via the receiver and the manual button on the motor good..
But with usals grrr just wont move at all.. long and lat entered etc and still wont move..
Reset the motor with pin also factory reset box and re id everything.
What could be wrong?? it is receiving the commands from the box, as its flashing orange etc..
please help im on my third weekend on this now lol :(
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Have you tried sendng it back to zero?
Forget USALs and use standard DiseqC, takes an hour to set everything up, but then will work until you next reset.
Agreed, I never could work the USALS thing on the ones I fitted, so used DiSEqC and everything on the major satellites comes in, though the minor ones do need fettling.
(Fine tuning with the analyser on the outgoing tuner port helps, though with one of the inline meters you will need to fit inline with the motor/LNB.
homerjay
Spiderbox 9000HD, Super DARK MOTOR, 80cm Dish, SKY+ HD, HTPC w/7MC
Chorley, Lancs
ive recently been messing with my motor and i no expert, but i did the silly thing of setting east/west limits both at 0, so the damn thing wouldnt move. was racking my brains for hours till i realised what i'd done.
dunno if this would work for you as im not sure what stores the limits, the motor or the reciever.
Yeshi
ive deleted all limits so isnt the problem...
looks like im going back to standard diseqc, but it seems weired that it worked then it doesnt.
Thanks for your comments :)
Dish isnt lined up because of it so ill have to re align at some point when the rain stops :)
For the football today ive had to program a funcard for a diferent type of box and fit it in the living room :(
