GSAT-11, Intelsat 38 (Azerspace-2) - Ariane 5 ECA (VA243)
tempo
47.5N, 42.2E / Russia
Test carriers from 4, 5 January.
tempo
Test carriers from 5 January (last night).
All I am picking up ATM from Intelsat-38 is the Beacon on 12745 H so I will check again this evening.
Test carrier @ 12575 V
All Vivacom transponders have moved to Intelsat 38 except one 11477 V 30000 I have no signal for this transponder,
Later today I will Blind scan 45 east to see if this transponder has moved to a new frequency outside the 11450 to 11700 band that I have already scanned V & H or maybe it is too weak for me to receive,
Signals much much weaker here in the East of England from Intelsat 38,
City TV 11635 V 30000 = 65% SQ with 88cm dish & TM6902HD,
Other channels on 11513 V 30000 are breaking up with 52% SQ I used to get a much better signal with Intelsat 904 on this frequency,
I will check out 45 east with the 100cm next.
With my 100cm dish 11477 V 30000 has returned,
Much weaker signals here in the East of England with the new satellite Intelsat 38 on all transponders.
What map ? if is-38 map on the left was correct a 45cm will get these signals but it does not.
There is no switch from my logs :confused. Nessun transponders went down overnight.
Yesterday
Today
Rasoul1910
Starsat 2000 hyper
Iran
So it looks like the map on the right is more accurate
No .I'm from West Iran no reception here with 90cm dish
ilgar
starmax
iran
Ben de iranin kuzey batisndaym 11477 30000 kirimli aliyorum
Welcome to the forum ilgar
I'm taking the north batisndaym 11477 30000 with Iran.
11513V - at or below lock
11635V - signal ok
offset lnb on 1m dish aimed at 46E. (although I do need to tweak the lnb setup on this dish)
Message of 24 Jan translated into English from sat1 | VIVACOM
We would like to inform you that the planned VIVACOM switch to IS-38 is postponed for February. All users of the service will be informed in a timely manner by a message on the TV screen, SMS and / or e-mail about the exact dates and actions required.
• Intelsat 38 (45°E), freq. 11,477 GHz, pol. V, SR 30000, FEC 2/3, DVB-S2/8PSK
• Intelsat 38 (45°E), freq. 11,513 GHz, pol. V, SR 30000, FEC 2/3, DVB-S2/8PSK
• Intelsat 38 (45°E), freq. 11,555 GHz, pol. V, SR 30000, FEC 3/4, DVB-S2/8PSK
• Intelsat 38 (45°E), freq. 11,595 GHz, pol. V, SR 30000, FEC 3/4, DVB-S2/8PSK
• Intelsat 38 (45°E), freq. 11,635 GHz, pol. V, SR 30000, FEC 3/4, DVB-S2/8PSK
• Intelsat 38 (45°E), freq. 11,675 GHz, pol. V, SR 30000, FEC 3/4, DVB-S2/8PSK
any info about dialog tv india beam move ?
All signals back to previous readings here on Intelsat 904:-
11477 V 30000 2/3 61%
11513 V 30000 2/3 64%
11555 V 30000 3/4 73%
11595 V 30000 3/4 74%
11635 V 30000 3/4 74%
11675 V 30000 3/4 74%
SQ readings via TM6902HD + 88cm dish
New frequencies will be in use when the change over eventually happens,
Преминаване към нов сателит
11475 V 30000 3/4
11515 V 30000 3/4
11555 V 30000 3/4
12520 V 30000 3/4
12560 V 30000 3/4
12600 V 30000 3/4
Dialog Television SATELLlTE MIGRATION
  • Phase 1 : From 10 PM on 28th January till 10 PM on 29th January
  • Phase 2 : From 10 PM on 6th February till 10 PM on 7th February
  • Phase 3 : From 10 PM on 17th February till 10 PM on 18th February
  • Phase 4 : From 10 PM on 19th February till 10 PM on 20th February
Since today, IS-38 is shown on Intelsat's Ephemeris page, and is indeed at 45.0°E now.
Ephemeris | MyIntelsat
TLE is lagging, as usual after a manoever.
