Guys need an urgent help with my STAR SAt sr-x130d plus
kingofking
i have a starsat sr-x130d plus, and i use my pc to upgrade it
Guys,
I have this STAR SAT reciver and i have the dreamloader software and i don't know how to use it, i mean how to upload the key to my reciver.
I am visiting this web site to obtain the latest keysand entering them manually. http://www.satnet.ch/file/index.php
which file can i use to update these keys automaticaly using the dreamloader software and not manually.
can anyone explain how to use the software and whic file exactly should be used.(kex, key, bin or which)
can anyone help or direct me to any
appreciate your co-op.
nhabib
STARSAT SR-X200CI
OPEN BOX AF1700
hey there visist www.satsw.net you will find everything you need there
kingofking
Thanks nhabib but what i need is not there, i have the software and i have the keys but which file to use this the question. i e. after i upgrade the software all my keys has gone.
when i go to TBS and enter 1234 then in each (viaccess, negra.irdeto,conex......etc) there is nothing there.
i don't want to add them manually as it will take all my day working on that.
