My Haupauge DVB Card came with Remote Control, but with no instruction on how to use it. any one knows how to use the remote control? is there any setup required or any installation tips...
If it's the same as the WinTv card remote, you should have a small infrared sensor which plugs into the back of the card and sticks on the front of your monitor. There should also be an element in the program group that will initialise it. Once fitted the thing should be ready to roll.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
