Hdmi and Dvi Signals,wireless transmision over a powerline adaptor!
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
just found a intrsting report,of a new item,that hits the market soon,presented on ifa in berlin!
very intresting!
__http://translate.google.com/translate?prev=hp&hl=de&js=y&u=http%3A%2F%2Fwww.golem.de%2F0909%2F69618.html&sl=de&tl=en&history_state0=[/url]
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Link does not work Turok
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
sorry was something wrong,in the link from google translate,now i have edited and it should work!
if not visit _golem.de
and then you see also on the first topic!
Topper
Still does not work, but google does just fine
_http://translate.google.co.uk/translate?u=http%3A%2F%2Fwww.golem.de%2F0909%2F69618.html&sl=de&tl=en&hl=en&ie=UTF-8
I have two of these adapters, they are rated at 200Mb/s
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
hm,i insert the link exactly how google shows me,this the first time that it not work,maybe the change something in htlm script--
realy you already have them?
what system is using to compress the picture signal,on transmision,will be deccompresed in the "end" of the powerline where you use it?
for example
we have to diffrent living rooms in a rentail flat,and both the nabour and you whould use the same system,at the same time?
how the system,can cutting,2 same sources,that use over the same powerline?
could it be happen,that you see the picture of your nabour and he see your programm?
the mush,of powerline are very intensive,this the reason why i never will use it,not good for medium wave recption and fm dx,and maybe also not good with so much irradiation for the health,i only read bad reports about this..
Topper
Well of course you have hit the nail on the head, it is not very secure, and in the UK because these adaptors are supplied with every BT vision stb they are common and now that the free football is finished on terrestrial via setanta, they are two a penny on Ebay, but still sell for reasonable money
_http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m38.l1311&_nkw=comtrend+powerline+adapter&_sacat=See-All-Categories
As regards the compression techniques used you would have to speak to Comtrend I suspect.
They are good for internet access somewhere remote where you are still on the same ring mains like a garden shed or garage
