Help again please
djc
DM7020-S
88cm Triax Dish
1.8m Channel Master soon to be installed
Doncaster
Hi
I have had to reinstall Win XP due to the problem as seen here:-
http://www.satellites.co.uk/php-bin/forum/showthread.php?t=32301
The problem I have is that a Sat Man is due any moment to re-align me to 1W, so what I want to know is there a quick program I can install to see if I am locked on to 1W ?
Cheers 4 any help.
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Not really, but he won't need that to re-align you if he knows what he's doing and has got a decent meter and/or FTA box, so don't panic. If he doesn't, then sack him. :)
djc
DM7020-S
88cm Triax Dish
Doncaster
TBH, didn't instill me with confidence and am doubting weather he has done it right. Hope I'm wrong.
BGonaSTICK
Brighton
What dish/setup have you got? Motorised? Where are you?
djc
DM7020-S
88cm Triax Dish
Doncaster
Hi
Its a 80cm dish not motorised and I am in Doncaster.
Cheers
Mickha
North West
Hi djc,
if you've got access to an old analogue box then you could test it using the d2mac channels that are still left on Thor, if you get the scrambled d2mac showing up on TV3, then your dish is at least pointing in the right direction, even though you will be unable to test the signal strength.
TV3 11.341 V
I hope this is of some use.
djc
DM7020-S
88cm Triax Dish
Doncaster
Nope, the only thing I have is this SS2 which I am struggling with.
