Tiggy
- Dec 31, 1999
Could you please help me with my boot problem.
I have recently used (succesfully) FW7020beta3 to add images to both my CF and USBkey with no problems.
My problems began when I tried to upgrade my flash image to the latest (dreambox-image-dm7020-20050912093221.nfi).
I booted holding down the lower left (V) button to get the network id.
I then entered this into my PC browser and uploaded the image and got the following error message after about 21% upload-
too much data (or bad sectors) in partition 3 (end: 02000000, pos: 02000000)
(I keep getting this error with other boot/IP/web uploads of different images.).
I tried with DCC but it will not enable a network>
Itried with Universal dreamup and got the following error message(s)
20:21:34 uploading image
20:50:39 verifying checksum
20:50:47 flashing image
Flash copy failed! result: -5
Flash update finished!! (result -6)
universal dreamup
8:21:52 PM Boxtype: DM7020
8:22:06 PM Ping result: OK, box is alive and speaking to us ;-)
8:22:18 PM Uploading file to box...
8:52:15 PM calculating CRC32 on STB...
8:52:24 PM box is flashing from its memory...
8:52:50 PM ERROR, flash-copy failed (RC=-5), box will be unusable now!!
I have also managed to format the CF card of all images and Backups. !!!!!
As I stand now-
when the box is turned on it loads an image (dvb7020 edition) and then shows that it is trying to load local settings.
Problem is that it does not and stays like that. I have left in this state overnight and still the same.
I can get a telnet connection via PC command prompt, but all it shows is the dreambox ADVANCED SETUP UTILITY.
http://www.satellites.co.uk/php-bin/forum/attachment.php?attachmentid=3585&stc=1
http://www.satellites.co.uk/php-bin/forum/attachment.php?attachmentid=3586&stc=1
Could you please advise how to remove all settings and enable me to start from a fresh with nothing loaded at all?
Looking about it appears that bad software is perhaps to blame and the NAND(!?) memory is at fault and the box needs to be returned yet again (3rd time).
Can anyone throw me a rope?
I will be eternally greatful.
Thanks.
:-lan2 :-lan2 :-lan2 :-lan2
universal dreamup
As I stand now-
Thanks.
