[HELP] CONAX keys!
Likes
Hallo!,
Can anyone help me with conax keys for thor satellite.
At this moment i have
Keys deleted by Admin. Please read the rules, they are at the top of every section. !
on my receiver MVISION and i use emu
Thanks before.
Likes
Yes those are the old keys.... no keys should be posted >.< :eek:
Just look in the usual places, the conax key has been posted although I'm going to test it right now so dunno if it works yet.
h**p://www.sat-key.org/
Is a good start ;)
Hope it's ok to put the link.
ciarank
Likes
FortecStar 5100 Ultra
FortecStar LifeTime Classic
belfast
#3
Is a good start ;)
i have a the new key codes but the are in lowercase.
does the fortec star allow you to enter codes in lowercase? or should i ienter it all in uppercase as i normally do
Likes
I'm not sure mate but I can confirm the new key works on the Dreambox all in lowercase.
I noticed that too and wasn't sure if it would make a difference if the letters are in upper or lowercase but I just copied and pasted the keys as they were and it worked, all in lowercase.
I would say just put them all in as lowercase and see if it works. If it doesn't and you put them in as capitals and it works then you'll know what to do for future reference :D
The keys do work though so good luck :)
EDIT: It technically shouldn't make a difference if they are capitals or not because the keys are hexadecimal. It only goes 0-9 and A-F and it's only when writing that we use capitals or lowercase letters. AFAIK hexadecimal lettering should work either way :)
ciarank
Likes
belfast
#5
thx for the info - will try to enter code tonight.
Razor
Likes
Ireland
#6
New Keys ( key 21 ) do work.
I got CNX back last night...With a new TBM file from DUDEZ.
ciarank
Likes
belfast
#7
working for me also. oh joy!
