Help:coship 2300fta=metronic Accessbox?
G
gigi69
Likes
FW(Emu) for Coship 2300 is good for Metronic AccessBox?
R
rxserge
Likes
non! il faut logiciel WINUPOAD 4.0
cable:
2-3
3-2
5-5
firmware=?pas encore trouver!
Mc Cyber
Mc Cyber
Likes
hi guys, does it's possible that there aren't solutions for Metronic Accessbox?I'have open it and there are: sti 5518bvc + 29lv800 and a good jtag port..it look likes too much at another receiver FTA example: coschip, ariza...I hope that someone find a solution. thank you.
Mc Cyber
Mc Cyber
Likes
this is the data of the metronic accessbox with winupoad 4.0 by null modem cable rs232:
DebugPort initialised to 115200, 8, N, 1
Failed to sense hot keys for the second time ... O[0] N[0]
No download demanded
Verify CRC => Part #01. START [7FF70000] Size[505644] CRC[D15812AB] Ver[ 13 ]
Terminating system services..
UnCompressed Image Size => [ 0x7FF50008 ] Bytes
Decompress Start => [ 0xC0783000 ]
Image Decompressed successfully...
Image StartAddress => [ 0x7FF70000 ]
UnCompressed Image Size => [ 0x7FF70008 ] Bytes
Decompress Start => [ 0xC0080000 ]
Preparing to start application..
BOOT ADDRESS => [ 0xC0192FBE ]
STAVMEM_Init()=Ok
STAVMEM_CreatePartition()=Ok
STEVT_Init()=Ok
STPWM_Init()=Ok
STI2C_Init(back)=Ok
STI2C_Init(front)=Ok
PTI interrupt level 6
src\pti\ptiinit.c 405> Suceesfully enabled the PTI interrupt
PTI_Init()=Ok
STCLKRV_Init(CLKRV2)=Ok
STCLKRV_Open(CLKRV2)=Ok
STAUD_Init(AUD0)=Ok
STDENC_Init(DENC0, InvOut 1)=Ok
STVTG_Init(VTG0)=Ok
STVID_Init(VID0)=Ok
STE2P_Init(EEPROM) Size[2048]=Ok
initterm.c, 1552 Info> Report module is initialised ...
flashdrv.c 1908> Flash Driver Init OK
main.c 352> Lnb [8] Sat [28] Car [40] Ser [32]memdata.c 307> Eeprom End Offset [512]
memdata.c 332> eDBE Box Info Size [28]
memdata.c 363> User Box Info Size [52]
memdata.c 394> Wakeup timer Info Size [224]
***************************** MPEG - ModuleInfo *****************************
Platform Id - STi5518
Toolset Used - DCU 1.8.1
Compiled On - Jan 28 2003 at 15:21:24
MPEG Module Version - Ver 1.3.14 Rev.0
VIDEO Matrix initialisation
stv6400.c 799> successfully created video matrix process
HWC_AVMATRIX_InitModule()= OK
vpwmctrl.c 215> Install PWM interrupt 11 at level 1
Res Start Address = C0783000
Res Data - 544F4F52 4F4C425F 00004B43 C0081238
|| eGOS Version 2.2.33.0 ||
|| PLATFORMID 551x Date Apr 21 2003 Time 11:55:17 ||
main.c 1118> Success in creating Common User interface
main.c 573> RF => CH No. [35], O/P Mode [1]
Summary of SDB:-
Name BlkStart PLStart #Records
Lnb C07EAE70 C07EAE80 7
Satelli C07EAED4 C07EAEE4 10
Carrier C07EAFFC C07EB00C 136
Service C07EC32C C07EC33C 406
_:-sleep_:-sleep_ eIRRXVer3.1.0.0 May 31 2003 14:57:20 _:-sleep_:-sleep_
mmi.c 260> Success in creating IR Receiver Thread
fpkeys.c 424> FPKeyBoard Thread created *[6] with StkSize[3072]
######## AFTER MMI CREATE()
Major[2] Minor[2] Build[33] Platform[551x]Toolset[DCU Version] Date[n] Name[3]
Version of May 31 2003 at 14:49:20
Built for Chip STi5518 in board CPU Clock Speed = 81000000
System initialised - hit return to enter testtool
Heap Remaining : Start[C03D53EC] End[C03FDBEC] Size[162 Kb]
Heap Remaining In SYSTEM PARTITION: Start[C01D011C] End[C030591C] Size[1267712]
main.c 754> Lnb [8] Sat [28] Car [40] Ser [32]
= eDEMOD1.0-STV0299 Build R1.1.9May 31 2003 14:58:43 =
hwc0299.c 4125> TUNER (STV0299) Module Initialisation
Creating TUNER module semaphores ...
LNB Power Control by CPU PIO[2000C000] [20]...
LNB Polarisation Control by CPU PIO[2000C000] [40]...
Selecting Tuner ... Type[0D] Addr[C0]
nsfilter.c 3400> SECTION FILTER Driver version[HWC_SFILTER_55xx/3.0 May 31 2003 14:59:31.]
nsfilter.c 3419> Successfully intialised the Circular buffer Manager ...
nsfilter.c 3552> Creating SFILTER MONITOR Process *[9] WS[9216]
NO_OF_SIMULTANEOUS_FILTERS => 32
FILTER_DEPTH_SIZE => 14
MAXIMUM_NO_OF_STREAMS => 32
nsfilter.c 3633> Succesfully Installed SFILTER module
NDB Ver 1.7.4 built on May 31 2003 15:00:42
NAVDVB Ver 1.2.6
BUILDER Ver 1.2.9
STORAGE Ver 1.2.2
MEMORY Ver 1.2.2
DEBUG Ver 1.0.3
ndbfcm.c 4366> Database successfully initialised
irdmon.c 449> Creating IRD *(5) WS[3072]
irdmon.c 499> IRDMON successfully created
navdvbif.c 379> Initialising Teletext...
eTTXT - 4.4.0T3
27/05/2003
Started Initialising...
Successfully Initialized Teletext Driver.
navdvbif.c 385> Opening VBIAppl ...
navdvbif.c 441> Initialised Audio WatchDog module ...
watchdog.c 697> Created the WD_Thread *12 Stk[4096]
navdvbif.c 457> Initialised HW watchdog module ...
dvbmmi.c 635> Successfully created TIMER_Thread
THE END
Is there a compatible path for this?
M
METANOF
Likes
Y HAVE A SAME PROBLEM WITH MY ACCESS BOX METRONIC BUT Y BELEIVE THAT ACCESS BOX = HOUSTON BM3000.
IF YOU FOUND THE FIRMWAR SEND IN MY E-MAIL: metanof*lexpress.net
Mc Cyber
Mc Cyber
Likes
cable:
2-3
3-2
5-5
HAVE YOUU FOUND AN SOLUTION FOR FIX METRONIC ACCESSBOX?
PLEASE HELP ME!!!!!!!!
daneelolivaw
daneelolivaw
Likes
Manhattan PLAZA ST450
45N 8E
#11
@MC Cyber
Please, witch software You used to get log report above??
Were I can get it??
Bye
Mc Cyber
Mc Cyber
Likes
For firmware (.urt) use winupload, for channels manager use stb editor.
Mc Cyber
Mc Cyber
Likes
Now I find a emu firm for see sec* vi*ccess n*gra..LIKE srtong, toomuch receiver are comatible with this (STI5518BVC+29LV800TA).
Please anyone help me for find this.
THANKS.
P
pajo100
Likes
1.2 /1.8 Channel Master fully 36v motorised 58west to 42east Pace MSS500 Positioner
,Technomate 6900 Super HD ,Humax 8100PVR oh and a Amstrad Sky+ digibox.
Ireland
#16
Any new patch for Coship 2300 yet??
Mc Cyber
Mc Cyber
Likes
http://69.56.220.20/index.php?action=downloadfile&filename=Kompleto Octubre_B39[1].01.rar
P
pajo100
Likes
Ireland
#18
Any for 3902 boot ??
Mc Cyber
Mc Cyber
Likes
ON WIDOWS XP:
GET TO START>ALLPROGRAMS>ACCESSORIES>COMUNICATIONS>HYPER TERMINAL
-INSERT A NAME AND SELECT AN ICON AND COM1 > PRESS OK
-SET BIT TO 115200
-PARITY=NEVER
-HARDWARE CONTROL=NEVER > PRESS OK
CONNECT METRONIC ACCESSBOX TO COM1 WITH NULL MODEM CABLE AND TURN ON(STANDBY=RED LED)
WAIT ANY SECONDS YOU CAN SEE ANY STRINGS ON HYPERTERMINAL
WHEN THE STRINGS ARE FINISHED PRESS ENTER.YOU ENTER IN TESTTOOL MODE.
WRITE HELP TO SEE ALL COMMANDS:
Testtool> HELP
The following commands and macros are defined:
DELETE - <symbolnames> Removes named symbols or macros
HELP - <commandnames> Displays help string for named commands and macros
GETKEY - Waits for one key and returns its value
GETSTRING - Waits for a string and returns it
HISTORY - <number> Displays the last commands or runs the selected one
POLLKEY - Tests if a key was hitten and returns it if any
PRINT - Formats and prints variables
SHOW - <symbolname> Displays symbol values and macro contents
STAT - Display memory informations
VERIFY - <flag> Sets echo of commands for macro execution
CLOSE - Stops logging and close the log file
LOG - <filestring><options> Logs all command to named file
options= W|A for write|append , I|O|R for input|input+output|output
results
default= L
SAVE - <filestring><constflag> Saves macros & variables/constants to nam
ed file
SOURCE - <filestring><echoflag> Executes commands from named file
BPEEK - <address> Extracts 8 bit memory value
BPOKE - <address><value> Sets 8 bit memory value
COPY - <address><range><newaddress> Copies local memory contents
DISPLAY - <address><range> Displays local memory contents
default = BASEADDRESS RANGE
<address><range><filename><option> Dump local memory con
file
option= W|A for write|append (default is w)
FILL - <address><range><value> Fill local memory with value
INTERRUPT - <level> Raise interrupt internally
PEEK - <address> Extracts 32 bit memory value
POKE - <address><value> Sets 32 bit memory value
SEARCH - <data><address><range><max> Searchs data in local memory
default: data=DATAVALUE addr=BASEADDRESS range=RANGE max_occurences
=1
the 1st match address is returned (0 if not found)
SEARCH_NEXT - Continues the previous search in local memory
WAIT - <millisecs> Pause for a time period (available with 1 tick each 6
4 microsec)
MMI - Direct key input to MMI (<ESC> to cancel)
SETPAL - To set palette
ZOOM - To Zoom Video
REZOOM - To ReZoom Video
FEREG - Print all register contents of 299
FERD - Read specific 299 register
FEWR - Write to 299 register
FESTAT - Print the tuner module statistics
DPOWER - Control the LnbPower OFF
DPOL - Control the LnbPolarisation H/V (0/1)
DTRANS - Control the LnbParameters(Diseqcswitch/Enablehighband/pol
DFIFO - Write single byte in DiSEqC FIFO
LNB22KHZ - 22KHz COntrol [0] Off [1] ON [2] DiSEqC
LNBPOWER - LNBPower [0] Off [1] ON
LNBPOL - LNBPolarisation [0] Vert [1] Horiz
DISEQCPOSI - Diseqc1.2 Command
SFILTER - Report SFILTER status ...
CIRCBUF - Report Circ Buffer status ...
FILTSTAT - Report sfilter statistics ...
DBEXTHELP - Print external comm
DBINTHELP - Print internal commands details
DBIMDPRINT - Print the details of IMD Strucures
EPGCAR - Print Full Carrier EPG Info
NAVTUNE - NavDVB tune request
DBPRINT - Print All the details in Data Base
DBBOX - Print All the details in eDVBe Structure
DBLNBPRINT - Print the details of all LNB's in Data Base
DBSATPRINT - Print the details of all Satellites in Data Base
SPLNB - Prints the details of specific LNB - SPLNB <Index>
SPSAT - Prints the details of specific S
DBCARPRINT - Print the details of all Carriers in Data Base
DBSERPRINT - Print the details of all Services in Data Base
SPCAR - Prints the details of specific Carrier - SPCAR <Index>
SPSER - Prints the details of specific Service - SPSER <Index>
DBCURSERV - Prints the details of the current carrier
DBLCNPRINT - prints the LCN details
IRD_START - To start the IRD Monitoring
IRD_STOP - To stop the IRD Monitoring
IRD_STAT - To print the IRD Monitoring current status
WKUPTIMERPRINT - Display Timer Details
WKTRLEAST - Display Recent Timer
Bases = binary (bxx), octal (oxx), decimal (xx), hexadecimal (hxx)
print b10+o10+10+h10 is equivalent to print 2+8+10+16
Operators = + - * / (arithmetical)
& ^ | ~ ! (logical)
Return code = each command returns FALSE if successful or TRUE if failure
some of them also return a data, like s=getstring
Commands = command recall from history is allowed with control keys
ctrl-u=move cursor left ctrl-p=move cursor right
ctrl-i=previous command ctrl-o=next command
Variables = integer, float, string
Command and macros can be used as statements or part of expressions,
if appropriate, where the assignment is made to a symbol whose value
is either defined or modified by this assignment. Generalised assignments
can be made to symbols of integer, floating point or string types,
including evaluation of arbitrary arithmetic expressions.
Commands and assignments can be combined into parameterised macros
that use FOR, IF, ELSE and WHILE constructs. Using the DEFINE
command these macros can be set up for later invocation. All blocks
within these macro constructs are terminated using the END statement.
I THINK THIS IS A KEY TO PATCH ACCESSBOX AND HOPE THAT ANY PEOPLE ARE ABLE TO USE THIS PROGRAM
