[Help] DCC Login Problem ..!
Donche-x
DM500S
Slovenian
I get logged in to ftp and it says on the bottom > PORT 192,168,10,4,6,99
< 530 Please login with USER and PASS. i cannot see files on left hand side
See the photo:
hxxp://i50.tinypic.com/f1mw48.jpg
I connected with User: Root and with Password Empty and Showed "Network OK" FTP CONNECTED TELNET CONNECTED/
I have accses on Telnet but in FTP i have a problem..Dont showed any files on left hand side..
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
It looks like you are logged in OK as FTP and Telnet are both green,
What happens when you click the little green arrow that points upwards ?
Retired human
I am not familiar with DCC (not sure why people just don't use a normal FTP client) but sounds like you are not entering a username and password. Or you are but maybe still using anonymous login.
pontiend
Contibruter
south yorkshire
If I remember right dreambox is the password for the DM500s.
Burnham Beech
OP says he logs in with password empty - which suggests there is no password set up on his box.
My suggestion is that he sets up a password - this is done using telnet.
