help Dish lnb arm
R
rasp
Likes
I have a metre lenson heath dish and the lnb arm which comes from the back of the diish is rusted through and nearly breaking has anybody got a old dish that they don't use anymore, because i have been told they have taken over by TRIAX and they don't make them any more , or can anybody recommend a dish i can use with my H to H mount and motor.
RASP
BGonaSTICK
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#2
Suspect that you may have to have one made, or have the existing one repaired. Make sure you keep the old one so that the length/geometry can be measured. Shouldn't cost too much. Check out your local engineering firms.
If you don't fancy that, why not try some HD fibreglass over-wrapping?
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#3
rasp said:
the dish is rusted through and nearly breaking
Removed an old Lenson Heath about a month ago which looked pretty rusty to me until I tried to break it!
It took some bending, so you may be lucky and get a few years yet.
I would wrap it in glass fibre material you can get at halfords if you're worried - like BGonaStick advised.
