satcure645
- Apr 11, 2008
- Age
- 50
- AS**O Nokia +DM500s+Topfield 3000CiPpro+Disec switch+65cm Offset Dish+8ft Mesh Type Dish+C/KU band LNB
- Malay91.5ele77az268
Hi All;
I'm newbie in DM500s. Just bought yesterday..with CardServer sharing to watch AS**O.
Set working fine but the problem is how to use my AS**O original card with internal cam(card reader)? Possible to use cccam2.0.4 to switch between card server and the internal card reader cam? or do i need to install additional cam software?
Any assistant will be grateful as I also need to use the original subscription card with the unit.
BTW I've know idea how to check what Skin the set is using. Other infos are listed below:
Software Version: 1.9.30.12.2007
SoftCam: 2.0.4
Software Management (april08) lolite
SoftCam: 2.0.4
