Help Dreambox 500s +tps
L
LOTUSSE38
fte nunca mais
pORTUGAL
Boa noite a todos, existe algum emulador para colocar os tps a funcionar, sem ter a dream ligada ao PC ?
O Vplug+SBCL vai buscar as Keys frescas a net ou é perciso fazer pelo TPSBIN extract. Obrigado.
Lucas
Lucas
Dreambox7020
Mars
Parece que a nova Mgcamd tem AU para TPS, mas eu ainda nao testei, aqui vai o link.
_http://rs85.rapidshare.com/files/36957325/mgcamd1_1_.23.zip
Fix for D+ 4102 provider ID
Changelog:
2007/06/13
v1.23
tps au (look on U: option), remove old tps.au file if any !
PW mecm.
experimental gbox client (client only, no forwarding),
config file - peer.cfg, cards list in /tmp/mg.info,
reports itself as version 2.0A (there was no such gbox version, can be detected).
if gbox client enabled, it always will be tryed first for irdeto, ignoring P: option.
tested using own local gbox "hub", this is recommended mode to use.
U:, N:, G:, P: options changed, read config file.
osd on disconnect/reconnect to newcamd servers (if S: +02).
SummerRain
SummerRain
DreamBox 500s
Portugal
só curiosidade... a nova Mgcamd tem AU pros nuetros ermanos?
Lucas
Lucas
Dreambox7020
Mars
Nop, somente para TPS e parece que para o Premiere tb.
