help for ProgDvb
Mc Cyber
Mc Cyber
Hi guys, I'm an italian girl, and i've a problem with the plugins of Progdvb.
there are about 25 plugins in my Prog..I don't know that to use to watch s*ca!!
Can someone help me!!please!!
BGonaSTICK
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Which satellites/channels are you after exactly?
Have you got something called S2emu?
...or Y*nkse?
Mc Cyber
Mc Cyber
...or Y*nkse?
I've hotbird/sk*channells.yes,there are s2*mu and y*nkse but i don't know were they go and how to go! Do they go togeter?thanks for reply!!
prof
prof
In the spare room.
Hi Mc Cyber,
Just open the main folder of progdvb,and put them in there, then when you run
progdvb, you can use the plugins drop down menu to enable/activate.
Mc Cyber
Mc Cyber
prof said:
Hi Mc Cyber,
thank prof, but them work togeter or single!? and do you know if exist another
plug in for key's auto uploading from provider?
prof
prof
In the spare room.
1. On hotbird found that it doesn't matter if one or both are enabled.
2. There is one called fenrir, but have not tried it.
Mc Cyber
Mc Cyber
I've fenrir. think that it's a good plugin! so i haven't problems by keys. do you use Progdvb?
prof
prof
In the spare room.
Yes, I am using progdvb at the moment.
Mc Cyber
Mc Cyber
i don't know if you watch italian channells(sk*),but i think that in your town is there a simil channells that use ird*to or s*ca2.
BGonaSTICK
BGonaSTICK
Brighton
I watch S*y Italia on my Skystar2 PCI using Mytheatre V2.76, and on my Skystar USB using ProgDVB (Latest version). There are no auto key updates for this, and you also need the following files to open it :-
S2emu.dll V1.0.7.0 or above, s2_hash_0070.bin, s2_Mt_0070.bin, s2emu.ini, s*ca2.cfg and your updated s*ftcam.key.
IMO you should remove all other unwanted plugins (including Y@nkse) to promote application stability.
STICK
Mc Cyber
Mc Cyber
were i find all this files(S2emu.dll V1.0.7.0 or above, s2_hash_0070.bin, s2_Mt_0070.bin, s2emu.ini, s*ca2.cfg)? are them all in a zip folder? i've only s2*mu.dll v1.0.6
prof
prof
In the spare room.
Put bin files, emu, and seca.cfg file in root directory of progdvb(main folder)
It looks like you have everything.
In answer to your earlier question, I haven't had any problems using pdvb.
Good luck
prof.
Mc Cyber
Mc Cyber
thank you very much prof, now i've found the latest version of s2*me with all files! now I try! bye
Mc Cyber
Mc Cyber
so*tcam.key goes uploading 1 time at mounth or at day?
BGonaSTICK
BGonaSTICK
Brighton
Don't understand your question?
I think that the keyfile tends to be updated once every month for S*y Itlaia. You can get one from www.dvb.lv
Where is your s*ftcam.key file?
It should be in this folder as well, assuming the folder is the root directory of ProgDVB, i.e. C:\progdvb\
STICK
Mc Cyber
Mc Cyber
thank you,exist a specific k*y for s*y?
