help !! how to enter key in starsat
Y
yasinag
How to enter keys in starsat SR-X3500. I have update it with latest
firmware from www.satsw.com
Yasin
D
daneshva
I have a Starsat 3500 CUCI too but I have some problem in updating my receiver. Let me explain it for you. I can connect to my receiver with Hyperterminal. Some info appears in the hyperterm window but I can not work with IRD tools. Would you please help me?
Y
yasinag
IRD tools is not working for me also. I used simpleupload2m.exe which is part
of firmware.
which version of firmware U receiver has ??
www.satsw.com has 2.5.222 and 2.5.226
Yasin
D
daneshva
Dear Yasin,
My Receiver versions are as follows :
Software : 11.2.225
Hardware : 6.6.006
Loader : 2.0.002
Would you please tell me what to do in details?
Y
yasinag
daneshva said:
Dear Yasin,
Software : 11.2.225
Hardware : 6.6.006
Loader : 2.0.002
I dont see any major difference after loading new firmware (2.5.222 or 2.5.226) from www.satsw.com except new blind search options.
Yasin
D
daneshva
I finally managed to update the firmware with the simpleupload2m that you mentioned. Thanks. But would you tell me how I can Upload the hex files? DreamLoader is just like IRDtools. Don't you know any other program?
Y
yasinag
I dont know of any other tool. May be if U know the OEM vendor, check with their site for updating softwares. Its from some Korean vendor.
Yasin
