help me
assar
Likes
please help me upgrade my receiver software
my receiver is lazer 2000 ic
and please tell me what to do if i want to download this software
M
msa225
Likes
Hello
Thanks for your guide.But let me know that is it any way who can input new data to receiver manually.Not by any software.
Which icons must be pushed on remote control for entering and editing necessary codes in "Super Lazer 20000"?
With Best Regards,
A.S.M
J
jchinquee
Likes
Entering "codes k*ys" on SL 20000... While on any channel, hit "0" on the remote control. The CAS systems will pop up. Select the CAS you want to edit and enter the new keys. Instructions for hex "letters" are at the bottom of the screen. Example, the top buttons on your remote are a, b, c, d...
Now that we've covered that, does anybody know how I can ADD CAS Systems to the SL 20000?
