help .. my motor dilema
georgefromasda
expert ..... in nothing
Likes
dreambox 500s
art card
liverpool uk
#1
so i have a 1 metre dish , asat motor
everything was fine , moved the whole dish/mount to a better place
now my pc cant move the damn thing , it will move via the buttons on the motor . i reinstalled windows still nothing , so i took every wire out redone the lot . nothing , so i dismanteled the lot made a 6 inch patch cable tried the motor infront of the pc only moved via the buttons on the motor itself
the picture off the satelitte is fine just wont accept any movement commands
so im returning it tomorrow ,
any last idea s ?
T_G
The Consumate Dreamer
Likes
211
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
#2
I am not sure I can identify the problem like this, but it seems to me that the motor driver (software) is not functioning. Normally,for small dishes this is performed by the diseqc driver, and most likely that your receiver needs these settings to be re entered. It could be that the plugin needs reinstalling or even more simply a box ticked.
Tell us a bit more about your receiver, and if you come accross the disecq issue.
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#3
im using prog dvb , my pc does everything , i even reibnstalled xp just to be sure .
never had a diseqc problem before , used dixie , kadiseqc and diseqc 12
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#4
The motor was checked infront of me and it was ok
I replaced the 450 w with a 600w psu in the pc , (ran the 450 as a secon psu works well)
redone the whole dish thing
still nothing
dixie
diseqc 12
kadiseqc
any ideas people as im really losing it
any known software inconpatabilities ?
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
#5
have you changed any software (i do'nt mean windows)
and when you did change windows have you sorted skynet.sys in system
read post 20
here
these are compatable
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#6
are they only for skystar cards ?
if not ill give them a go
thank s :)
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#8
well i done a full reinstall of xp (new disk)
installed mininum drivers , no av or firewall
still no joy
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#9
i spent last night making a new tower
2.8 ath xp 512 ddr asus mobo ati vga
still the same
this is the card btw
hp://ww.technotrend.de/english/download/tt-dvbsat-pci.jpg
*edit*
just remembered i had a 2 port isolation switch which i dont use
regardless to say that has just been disconnected andf it still wont drive
**edit*
so it must be the pci card , possibly would a diseqc switch do the job ?
btw i used to own 2 computer shops and i still sell pcs thats why i have all the hardware / software
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#10
i take it youve read and already done this?
Notes for this version
First, you must close all DVB applications.
Then save the new version on your PC and extract the files into a new folder.
For the new software you must also update the drivers for your DVB-card.
If you use Windows 98, you will need the CD named "Installations - CD for MS- Windows 98"
Open your "Device Manager" and look for the topic "network cards" and
"remove"/ "deinstall" the device "Virtual DVB-S/-C/-T Network Adapter".
Look for:
"TechnoTrend - TT-DVBsat PCI" or "TechnoTrend - TT-PCline premium" then
choose "drivers update" on the tab "Driver" and
follow the instructions of the operating system.
You can find the new driver-information and the new drivers
in the main folder of your new installation
(the folder you extracted the new files to).
Please use the function "Remove" on the tab
"Start"-"Settings"-"Control Panel"-"Software" for the software
"TT-PCline premium" first.
Restart your PC, then run the file "setup.exe" to install the new software.
Follow the instructions of the installation.
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#11
just tried it again :(
still not working
thanks bronking
ill make a partition and try win me
you never know
Lancelot
Likes
SS1.
36v H to H 62E - 61.5W
South central
#12
Which drivers are you using for the card there ? 2.17g ??
Odd this one. :confused
L.:)
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#13
L.:)
hi lancelot
im using 217s
i have also tried 219s
no joy
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#14
kinda come to a conclusion
1 its not the motor (it moves via the switches on it and ive seen another reciever move it )
2 its not the wiring , totally replaced and all new f plugs (signal on hotbird 100%)
3 its not the psu (had 2 working on the pc)
4 its not the pc , tried 1 other and built a new one to try it (also windows)
5 all drivers and diseqc software tried different combos
6 even a different dish has been tried
for the first time in ages im beaten .
so my only ideas left
1 new sat card / reciever (id like a dreambox )
2 new motor
thanks for the help guys the wifes patence is only so strong and shes not happy over the time im spending on the sat and its not working
i think ill just stick to a static dish :)
thanks
Lancelot
Likes
SS1.
South central
#15
New motor sounds good :)
36V H-H with a Vbox will sort it. With 99 memories and a remote control, it will futureproof your system if you ever want a larger dish and they're generally a sturdier arrangement.
I've always run this way as I prefer manual rather than auto on the whole.
Rgds
L.:)
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#16
can only echo what lanceloy said,
there so much less strain on cable, pc card and cpu that the difference/performance is very evident
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#17
36v hhmmm
thanks people
anyone want to buy a asat motor , sort of works ;)
actually i was thinking of a small manual diseqc switch
Lancelot
Likes
SS1.
South central
#18
Switch for what sorry?
Do you mean for use with another reciever as well.
L.:)
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#19
L.:)
no,i dont know what its called , sends a east/west diseqc signal to the motor (30 quid at merseysat) its not a 36 v one its a coax only connection
