Help Needed in buying a Motor
rleone
Hi All,
I have a Dreambox 5620 with an 80cm dish,Im thinking about buying a motor for the dish so I be able to pick up more satellites up,please can someone tell me what motor to buy,as theres so many about,I have seen one one Hxxp://www.dvb-shop24.net Moteck 2100A Dish Motor with DiseqC1.2 and GO to X for 30 pounds.
ManyThanks
Richard
whatsthis
DM7020 Screambox
MAC OSX & windowzz 98SE
Gemini
1664 on tap
13°E
Hi rleone
I have the Moteck 2100A Dish Motor with a 80cm dish and it works great. Got it from a german company on ebay with the bracket. A motorised system are well worth the investment.
Only advice I will give (I'm sure you already know) is that you need to fix an upright exactly verticle and solid. I concreted 2 posts in the garden and bolted the motor to them.
Good luck and happy searching
Agree with Whatsthis, I have a Moteck and it has been troublefree, worked on one the other day which had got a bit slack after 3 years with a 1 metre dish, went through the tightening procedure and now working as new. :) At £30 it is a great deal. :)
rleone
Hi All,
many thanks for the above info,it look like that I will be going for the 2100,I will be placing the order when I return from my hols next week.
Richard
hughgk
Conax Silvercrest SL65 Receiver
Wicklow, Ireland
Hello rleone,
I'm new to this satellite stuff after buying a cheap Lidl kit a few weeks ago.
I'm enjoying it so much I bought a motor - a Motek SG2100, and with the modest amount of effort I'm happily skipping from Astra 28 to Astra 19 to the Hotbirds on 13 and back, from the comfort of my sitting room sofa, with a humble 57 cm dish. The build quality of the motor seems A1 and you can hardly hear it as it moves.
I settled for the Motek after reading this review:
http://www.satcritics.com/index.php
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
You said you were going to attempt to adjust out the backlash on that motor Rolf.
Glad it worked.
Worth posting the procedure as a sticky maybe ???
L. :D
rleone
Well Guys,
I couldnt wait any more so I have ordered one while being still on hoilday,,,,
