georgebr
please guys i need help for using my dreambox on the ethernet port on the bt voyager 205 adsl router,im trying to acsess a tcp server but for some reason it does not work.
help appreciated.
help appreciated.
BonceChops said:Does the ADSL router have a built in DHCP server in it? Most do. If so enable it and then select the use DHCP option on the dreambox. That should do it.
Neil
georgebr said:guys hi again i appreciate your replys,the problem here is that this bt router blocks ports 4000 to 4020 tcp.so sometimes my dreambox will work for 10 min and stops or will never work at all,i think the router times out on the ethernet port.when i ping the tcp ports 4000 to 4020 it works fine its weird this bt 205 is a very bad modem if you guys have expericenced anything like this and solved the problem please reply to me.
thx
