Help on C+ Dep....
Wobbler
Wobbler
Likes
Essex, UK
#1
Hi Gurus,
Just checking C+ De***te 1 to 3 are gone and it's not just me malfunctioning!
Using Hydra7000 Poseidon 108 with mgcamd[20.01.2005] and Ma**'s KB.
Clearing the TAQ****s ok so the C+ De***s must be permanently changed to a different flavour of S*c* ??
Thanks.
__________________________________________________
Dreambox 7000S - 128 USB external storage
80cm dish 30W to 42E - motor and LNB unknown
Edon 2150 VBox positioner.
S
Satslut
Dumb Satellite Babe
Likes
Technomate 5500CIP
Force 1145S
Pace 2600
SS2 pci & USB
Channel master 1.8m
1.2m & HH motor
AMD 64 bit, Linux & Windows XP2
Ibiza, Spain
#2
Wobbler said:
Hi Gurus,
Thanks.
The channels you mention have changed to NDS encryption, so effectively they are gone forever, UNTILL !!
Wobbler
Wobbler
Likes
Essex, UK
#3
Right, thanks for that!
I was mislead by the Enc code across the top of the screen display - shows 'I', 'S', and 'V', with the 'S' highlighted in yellow so I assumed was still S*c*a. Must have lost it's 'N' in the transition. Cheers.
P
PCD
DB Magician
Likes
D+ 40 Latino and taqs still ok with mrv221, but not with scam2.5c in dm.
Wobbler
Wobbler
Likes
Essex, UK
#5
Not sure what this channel is, was only trying to get it as the Jubbly site said the Chelsea game was on there.
I can get TPS S**r ok but this one doesn't show in the list, according to Jubbly it's -
10796 V 27500 3/4
- but when trying to do a manual transponder scan it doesn't find anything and just hangs. Maybe it needs the PIDs entering but I can't see any way to do this with the available DB settings. Thanks for any pointers.
Wobbler
Wobbler
Likes
Essex, UK
#6
10796 V 27500 3/4
I meant to put this in as a new thread - bugger!
S
stive meister
Likes
JDHJVHSJKV
evrywhere
#7
c+deporte ha gone.it seems that they are going on bcause olso canal+ ,2 have gone.
