Help Please
B
bigscreencrazy
Likes
SKY PLUS, BT OPENWORLD
#1
HI FOLK,
JUST SET UP FOR MOTORISED SYSTEM FOR TECHNOMATE 1500 < mOTECK 2100 dISEQ 1.2 ,80 CM DISH AND FOLLOW THE TUTORIAL.
GOOD SIGNAL ON THOR .HOT BIRD AND ASTRA 28.2 ect.
when do it manually motor 1.2 on setting.
bit when change to USALS , everying went wrong. Person who did with Sat meter said usal is rubbish snd left me to motorised seting .
It is true or do i need to change to usal.
please help:::
bigscreen
Rob
Rob
Likes
Technomate TMS-1500 CI+ &quot;patched&quot; receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
#2
It's all a matter of personal choice really, I use 1.2 because I've used it before not that there's anything wrong with Usals in fact for finding weak sats its supposed to be better.
As I said I use 1.2 and if you want to continue with that just make sure that all your satellites have Diseqc 1.2 selected and not Urals.
Look at page no 13 in your user's manual, it describes both systems.
Likes
1,296
#3
As Rob says, it is a matter of choice, I have found it very good on some motor/receiver combinations and not so good on others. To say it is useless is absolute tosh though.
All you have to do is find a reference satellite, enter your coordinates and then it should find the other birds, as long as the dish is setup properly that is. :)
B
bigscreencrazy
Likes
#4
hi rob,
thanks for your advice. any chance would you explain of patch . i am quite new in Sat .is it a kind of modded Playstatino 2 or kinf of software hack?
bigscreen
Rob
Rob
Likes
Essex
#5
It's an update for my receiver's software which allows me to watch certain encrypted channels, wouldn't be without it.
:-welcome
B
bigscreencrazy
Likes
#6
hi folk,
sorry to delay reply and thanks for kindly explanation. i am looking for how to patch my technomate. my understanding is via null modem cable with pc, download soft ware connect the receiver and flash it.
but i look at menu shows a lot of channels including viaasses,ireto cryto etc ,i think software version june 2005, is it patch although i can see only freeview.
can anyone kindly point how to patch the procedure or link please,
thanks in advance
bigscreen
B
bigscreencrazy
Likes
#8
hi folk,
i did it ,patch the receiver via darkman patch, look like saving a lot on cam and card ,it ia a shame not in stick how to patch.may be rules.
but thanks for the hint and link.
guys who just bought technomate 1500 should go to alsat .that is my advice for newbie.
thanks folk,
bigscreen
sonic1
sonic1
Likes
101
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
#9
Well done m8!
Dont it feel good to have figured it out for yourself.
Now you can help others and share you views and findings!
erosennin
erosennin
Likes
Solar System, currently on planet earth.
The other side
#10
Congrats bigscreencrazy
:D
Slot Jockey
Slot Jockey
Likes
Technomate TM-1500 CI+ receiver, Lenson Heath 90cm dish, Triax diseqc switch, Triax and Cambridge Gold LNBs, Titanium 2 card
Hampshire UK
#11
Hi bigscreencrazy - and all forum members,
Which patch from the list given did you use?
I can't see one for the 1500 or even the 1000, just the 5xxx, 7xxx and 8xxx series, so I'm concerned over picking the wrong one
Can anyone further advise if the Tit card has any function or use after the patch is installed?
As a total noobie I've haven't had much joy with the card yet but I'm sure that's down to my inexperience so far in trying to suss out the correct programming method.
Thanks in advance
SJ.
Slot Jockey
Slot Jockey
Likes
Hampshire UK
#12
Ah-ha!
I've sorted it out as well now!
I hadn't realised that it was another forum and that I needed to register (said I was a noobie, didn't I?)
Once that was done - Bingo!
Follow the threads and there it was.
