Help problems finding Eutelsat w2
J
junger
I can find astra 1 at 19.2e but cannot find eutelsat w2 at 16e has anyone any ideas please
gameboy
gameboy
Ding Dang Doo
Scotland
A few questions first...
What size dish?
Are you using a motor?
Did it work and you lost it?
Has anything changed?
Where do you live?
All these answers will help you get the best advice...
J
junger
What size dish?
Where do you live?
70 centimeters dish
universal lnb
Warrington
26 degree inclination
The system was setup by the shop but they are now closed
gameboy
gameboy
Ding Dang Doo
Scotland
So how do you know the dish is pointed at 16 East?
Motor, Dual LNB - other?
Dish size should be fine check here
J
junger
fixed dish
universal lnb
gameboy
gameboy
Ding Dang Doo
Scotland
If you are receiving Astra at 19.2 and the dish has a single LNB then you won't receive any other positions.
You would need two LNBs placed beside each other on an arm to receive two positions.
Or am I missing something?
J
junger
sorry, i can move the dish which is what i am doing, i csn pickup astra 1 satelite (signal stregnth and quality when i select asta 1 in the menu setup but and as i said i then select eurosat w2 (which my card is activated for) but cannot get ant stregnth or quality. any ideas please
J
junger
do you know the transponder setup and what it should be Gameboy? in case that is incorrect
Topper
Topper
Amo Amas Amant Admin
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
Choose the creamy ones for Europe on here like Alsat
gameboy
gameboy
Ding Dang Doo
Scotland
You will find a full list of frequencies and channels here.
Are you using a meter on the dish to find the signal?
You have to move the dish West from Astra - only a few degrees - once you have some signal fine tune by moving the dish up and down slightly and the LNB out and in and you can try turning is slightly both way to find the best signal.
Remember to wait a few seconds for the digital signal to lock before you adjust again. Best to mark the dish LNB position on 19.2 E before you start so that you can get that position back.
If you find what you want use a different pen and make that so you can move between the two.
J
junger
hi guys
I am moving between astra1 (19.2) degrees and hotbird (13.0) eutelsatw2 is in the middle (16.0) but i just cannot find it,.If the meter is picking up both is there any other reasons you can think of why i do not see eutelsatw2.
any ideas?
What transponder do you have set for 16E?
P
pothead13
Technomate 1500ci + 1000d super +
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
pc + laptop on network
uk
and dont expect the same signel as astra and hotbird
J
junger
please explain so that I can reply. Thanks
When you select 16E, what transponder does it show?
J
junger
The Reciever is a Televes Rsd7254
the lnb is a universal 0.3 db. Single planitum
Does That help?
J
junger
The transponer shown in the menu is (10957H 2821).
Is that ok?
J
junger
I am looking at a spectrum envelope on the Sat Meter but do not see any other transmissions between Astra1 and Hotbird. This has totally confused me, additionally The receiver in Signal Test does the same i.e when I selet Hotbird and turn the dish to it the stregnth is there, same ith Astra1
That symbol rate is very hard to find, try 11554 V 28800-7/8
