help sky digital with DiSEqC_1.2
arabicradiostations
hi ,
can anyone help,i'm waiting sky installer to come and install sky. i have a 60 cm dish with DiSEqC_1.2 motor,i know the sky digibox can't move the dish but the question is can the receiver still pick up the signal if the dish pointed on astra via the DiSEqC_1.2 motor?!!
Shouting edited out by Admin
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
Yes, but why do you have the motor fitted?
arabicradiostations
because i have another receiver technomate and i need to watch some channels on hotbird.are you sure about picking up the signal via that? have you tried it,thank for the quick response.
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
If the dish is set up on the East West Arch correctly and you use the Technomate receiver to drive the motor to 28.2 East.
If you have the cable feed from the dish split to both receivers then the Sky box will receive the channels on 28.2 East, that is my understanding.
I may be wrong as I don't have Sky but I'm sure someone else will confirm either way!
arabicradiostations
hi ,
You may find that the Sky installer will not install to a motorised dish and as a general rule it is not a very satisfactory for operation, as the dish needs to be parked at Astra 28.2 overnight for the upgrades and phone home requests. At the very least I would add a twin LNB and run a separate cable in to the Sky receiver, but if you can't do that then it should work on loopthrough if the other receiver is switched off.
iceman
3.0m Motorised Channel Master + 4 fixed dish Amstrad_DRX890C
DM7020s,DM800se
UNOHM EP314 PROMAX TV Explorer
Kyrenia - NORTH CYPRUS
Why use such large letters? looks like you are shuting.
Providing you have a digital receiver to drive your DISEqC motor to 28.2E & providing you have an LNB with more than one output,it should work.
arabicradiostations
the software download for sky will be via the telephone,so what you mean is sky can't move the dish but still can get the signal from the cable even via the motor ,offcourse if it's pointed on astra 28.
Wrong wrong wrong - all software updates come via the satellite signals - usually delivered overnight. The phone line has NOTHING to do with upgrades at all
The software download is off air, not via the telephone, if you are getting a subsidised box though, it needs to receive the request off air to phone home.
arabicradiostations
that's fine,don't panic both of you, via teh satellite,so what is the answer for my question? can digibox receive astra 28 signal via motor?!!!! 1 million dollar question!!!!
Your question doesnt make sense. The digibox will be able to get the signals as long as
1) the dish is pointing at 28E
2) the dish is big enough for your location to actually pick up the signals
HOWEVER - digiboxes dont really like losing lock on the Sky signals, you will probably find that you have to unplug the digibox regularly to reset it. You would be much better off rigging a permanent dish specifically for 28E, and using this for the digibox.
arabicradiostations
i CAN'T UNDERSTAND WHY MY QUESTION CAN'T MAKE A SENSE,IT'S SO SIMPLE,SKY DIGIBOX IS NOT DiSEqC_1.2 ENABLED,SO IT MIGHT NOT BE ABLE TO PICK SIGNAL VIA THIS KIND OF MOTOR AS THE SIGNAL HAVE TO GO THROUGH THIS MOTOR.
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
The motor has no effect on the signal, yes it will work.
The guys are just warning you of the pitfalls of not keeping the
dish at 28E, It will cause the box to freeze and will be a a pain in the ass!!!
But go ahead and try it and let us know how you get on.
As sonic says, as far as the digibox is concerned the signals will pass transparently through the motor. Personally what I would do is to put a dual LNB on the dish, and take the second cable direct to the digibox.
BTW - Please dont type all in CAPITALS - its considered to be SHOUTING and makes people reluctant to chip in with advice.
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
thanks every one for the responses,that all depends on sky installer.
Come back and let us know how you get on.
