HELP! soyo graphic card driver
hillen1
windows 98
echostar 3600dip reciever
channel master 1.2
Hi can anyone please help.. the thing is i had a virus on my computer and had windows 200 previously, i then lost the win 2000 disk so i installed win 98 but my graphics are very poor. its like 16 colours, how can i change it to 256 colours? someone told me i need to get a driver for my graphic card, all i know its a SOYO one and its built onto the motherboard.. any suggestions on what to do?
you advice will be highly appreciated..
hillen1
windows 98
channel master 1.2
rolfw said:
Have you tried updating the drivers using the web interface hillen1?
Otherwise, register here, there will probably be something there http://members.driverguide.com/ums/index.php?action=r
Alternatively, get yourself a version of XP, loads around. :)
the thing is i have a pentium II so its quite old and i had win 2000 and that was fine for me, is it possible to download a version on 2000?
any suggestions?
kind regards
I'm sure you will be able to find a version somewhere, try searching with google.
hillen1
windows 98
channel master 1.2
i've tried everything i cant find it and its making it harder as i only have 16 colours so the graphics are very poor to search for things.. i've registered with driverguide but i dont know my model number or anything about my motherboard hence me not being able to download correct file... is there any way of finding out,, all i know is that its a soyo ..
cant find a free win 2000 version anywhere also..
im quite new to using a pc so its sort of difficult..
hillen1
windows 98
channel master 1.2
can anyone help!!!! i have coursework to hand in and i cant read the screen without getting a migrane!
How does the the device manager describe the graphics adaptor?
hillen1
windows 98
channel master 1.2
it says standard display adapter.. VGA
hillen1
windows 98
channel master 1.2
which version of sandra shall i download.. is it the standard version under the overclockers club or under the tech pc?
hillen1
windows 98
channel master 1.2
just a q, when installing the file that rolfw mentioned.. would i go to update driver and enter the file via that method or just open the file downloaded using winzip.. and click on setup? i tried that method but it doesnt open
hillen1
windows 98
channel master 1.2
the error message reads
cannot install: SETUP or INSTALL program filename contains folder informatio. use Actions/Checkout instead..
(thats when i click the "setup" icon.. the computer one)
hillen1
windows 98
channel master 1.2
polomint the file i downloaded just open.. it says thuis file must run on windows NT
Just go and but a cheap graphics card from the local computer shop. 20 or 30 quid will sort all your problems.
hillen1
windows 98
channel master 1.2
im a student and broke.. my graphic card works perfectly before i reinstalled win 98.. all i need is a driver. i know i could get one from the shops but if i can get something thats available to download it doesnt take a scientist to work out which option is more viable..
PoloMint
Super Minty Mod
1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections
Fife, Scotland
Sorry, Sandra doesn't support Win98 any longer, I should have checked that. You could just take your card out and look for the maker and model :)
hillen1
windows 98
channel master 1.2
its built in so i cant check it, all i know it that its a soyo one..
i tried to open the file but it now says :
"setup was unable to complete the installation. check your progress log in your windows directory for more details"
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
If it's a built in one then you will need the motherboard drivers and not the one I found above.
L.
