help to get max signal
nitefire
nitefire
1M Dish TD110 Diseqc USALS Twin LNB Tecnomate TM-5302HD
Pair of T&K brackets
Grays,Essex
I live in the southeast of England and trying to aling my 45cm dash dash up
I only get singal quality 95 and signal strength 60 and nothing but a clear sky view what ever I seem do I
can not get max strength what leaves me a broken picture on sky travel channels and ITV 2 can some one tell me is a meter needed?
gameboy
gameboy
Ding Dang Doo
Scotland
What have you tried to line it up so far?
nitefire
nitefire
Grays,Essex
With sky box?
60% strength should give you reasonable reception, if you are getting dropout on some channels, it is possible that you may have a fault on the digibox, what is the make and model?
You can always use the manual tuning function in the installers menu and select the specific transponder you are having problems with.
nitefire
nitefire
Grays,Essex
Thanks Rolf I'm using Panonic B30 software 1.2F43
is a meter needed for the job?
Many people do it without, but a meter makes it easier.
