Help to set up sky box
bazer42
sky box 42cm dish
in Austria
Austria south
HI all
I need some help i live in Pörtschach Carinthia Austria ( South part on the border of Slovenia ).We can get channel's 4'5' and a few free ones
Haw can i set up the sky box to get some more channel's.
The sky box is sky+ is there a way to use the record on the box.The box is
3years old.
I have bridged the 2 aerial in puts so it works as one.
If some one can help us get the best from the sky box.
IF you need to know were we are i can send you a Google map.
Look forward to your Help
Bazer42
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Welcome to the forum bazer42
Well if you are getting what you say on a 42cm dish then you are doing very well, obviously Eurobird one will not be a problem but to be getting 2D?, well I am surprised, however only increasing your dish size will get you more but how much more I cannot say, perhaps another member in Austria can say.
In order to make use of the recording facility I believe you need a valid subscription card which is paired to the stb but you should have a dual output lnb with two cables supplying the stb otherwise you will not be able to view one channel and record another.
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
Hello,
Your region is out of footprint which means that some km further the reception could vary but i've found this thread: _http://astra2d.proboards31.com/index.cgi?board=Austria&action=display&thread=564
This means roughly that a 2.40m should do the job.
bazer42
sky box 42cm dish
in Austria
Austria south
HI All
Thank you all for the fast reply
Just one more thing as you all know i run my sky+ box on a 42cm dish.
is there any more channels that i can get. On my old box which is 3 years old we could get true movies but now i had to use the sky+ box we can not get them.I had to change the box over as the remote stopped working
put in new batters red light came on the remote, and then stopped working has any one got any ideas on how a can get it to work.
Thank you all for your time.
Barry
Topper
bazer42 said:
HI All
Barry
Why don't you just buy a new remote they are £5.00 - £10.00 on Ebay
True movies and true movies 2 are on EB1 S1 beam you should easily be able to get them try a scan of 11642 V 275000 2/3
Bazer42
What do you mean by that? It could well be the cause of your signal loss on the required channels.
