help with nicostar
alinijpels
Likes
My hobbie is satrelites
the Netherlands
#1
help how do i put files in nicostar with pc my hw is 1.29 can someone help me please
Topper
Topper
Amo Amas Amant Admin
Likes
3,346
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
alinijpels
I think people will require a little more detail than that in order to be able to help you. What model Nicostar is it? what does hardware is 1.29 mean? Does your manual not explain how to upgrade the firmware Do you have the software to do the upgrade? do you have the correct cable to connect from the receiver to the PC? :rolleyes:
T
tamazgha2003
Likes
dreambox 500s
tamazgha
#3
try this out
power off the receiver
start the programm ftlink or upgrade 32 (same as coship)
hitt the software upgrade button
chose the binfile
power on the receiver and wait till the receiver shows "GOOD"
Disregard if the computer says transfer complete.
the procedure is same as coship but the binfile(firmware) is different
alinijpels
Likes
the Netherlands
#4
he guys thanks for your reply I upgrade the software with edision 2100 fta but the problem is how can I put the keys in the receiver i have to do it with a r232 kabel but what files do I need
ps were can I find this binfile were do I have to look for
T
tamazgha2003
Likes
dreambox 500s
tamazgha
#5
no need to put keys on it
just active the emu by pressing: menu----system installation---6040
alinijpels
Likes
the Netherlands
#6
ok thanks i will try that
