Help with settings for motorised pls
djc
DM7020-S
88cm Triax Dish
1.8m Channel Master soon to be installed
Doncaster
Hi
The Sat Man is coming on Saturday morning to install my SG2100 which I purchased from Holland (thanks to a suggestion on this forum) :)
I have a Skystar 2 v2.3 and have been using a combination of Prog DVB and DVB Dream. Prog DVB is going to be a non starter for future due to the problems with some Thor Channels. So I am going to re-try My Theatre 2.76, as most people seem to recommend this on here. I did try this before, but thought DVBD/ProgDVB were easier on the eye, but am willing to give it another go.
So here are my questions:-
1)What are the best files to use in conjuction with MT 2.76 for DiSEqC controls, as I have seen several versions and am getting confused ? Do i just need to install DiSEqC 1.2 for SkyStar2 v1.8 ? Also what about DisEqc 1.2 plugin V0.85 for MT ?
2)If it is Skystar 2 v1.8 I need to install, I am confused at this bit "Set your correct Longitude,Latitude and H-H Motor Type".
3)Currently using the SS2 4.22 drivers, am I correct using these ?
Any other things that I might have missed would be appreciated. I'll probably have forgot about something I wanted to ask, so might add some more questions later.
Cheers for any help :)
