help with sky star2+Progdvb
M
Mr.No
Likes
satelite
sky star2
ksa
#1
hi
I havr prp. with my sky star2 or progdvb ...!!
coz. when I am searchinf 4 chanels I don't get excebt litle chanels
but the rest of the chanels does not apear ... anf if I use downloaded chanal list the rest of the chanals that apear now don't have any signal !!!
by the way the version is " ProgDVB4.85.3eeFullInstall "
so what is the prp. here ?
Topper
Topper
Amo Amas Amant Admin
Likes
3,362
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
Welcome to the forum Mr.No
Unfortunately you are using acronyms that people may not understand e.g. prp? go on give us a clue then????
Exactly my point what is prp?!!!!
M
Mr.No
Likes
satelite
sky star2
ksa
#3
prp. means Problem
coz. means Because
and sorry for that
member91040
member91040
Likes
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
INDIA
#4
from were u are downloading channels list, Pls submit it here let me have a look, It should be in .ini and let me try to arragne it properly.
Lancelot
Lancelot
Retired Mod
Likes
SS1.
36v H to H 62E - 61.5W
South central
#5
You probably need an up to date transponder list first.
Unzip this and replace the .ini files in your ProgDVB/transponders folder.
Then make sure your dish is lined up on the correct satellite and re-scan.
Rgds
L.:)
