Help with some frequencies
G
Gentleman
In the viaccess keys I find some keys for Canal plus in hot bird but the only canal plus I find in hot bird is under frequency 10892 which is scrambled with media guard not viaccess. Anyone know what frequency for canal + that works with viaccess ?
Also, what is the frequency for "Arabesque" on hot bird ?
Anyone is able to open the TPS star with the currently published keys ??
Canal Plus is a form of generic term (the broadcaster seems to have few territorial boundaries)
If its viaccess you require then the French bouquet is probably the only one (the films will therefore be either dual broadcast or in French - Version Originale - only )
