help with superjack dg120
Likes
texat 2xvacI 9300
scotland
#1
:-doh2 hi everyone i got a superjack dg120 discq motor but i don't have a hand book for it so my problem being i don't know what elevation to set it on for my lat-57,30.33N and long 1,47,55W can anyone give me any help as to what i need to set it on or e-mail me the page in the hand book the tells you how to set the elevation and so on or tell me where i can download a copy of the handbook.my e-mail addy is richard-32@hotmail.co.uk.
many thanks to all who help me :)
kitoog
Likes
dreambox 7000s w/160 Gb hdd
superjack dg120 diseqc motor
lidl 80cm dish and lnb
ireland
#2
i have an dg120 myself but cannot find the manual.but i think its the same as setting up a moteck motor.you set the latitude on the motor to 57 degrees.the declination at that latitude is 7.85 degrees.then the angle of your dish is (30 - declination angle)=30-7.85 =22.15 degrees approx :D .links here for dish setup and angles etc http://sadoun.com/Sat/Installation/HH-mount-installation.htm .there are guides in the stickies for motor setup also.by the way,is yours the newer superjack dg120+,the plus being addition of goto x/usals.makes setting up dish really easy.very good motor and with usals addition its even better.
Likes
texat 2xvacI 9300
scotland
#3
hi there i don't know if it is the + dg120 i have i just know it has 2 buttons for east and west that you can use while setting it up to save you from use the sat box.I will try the info you gave me and see if that does the trick :).With a bit of luck and messing about it might.
thanks again:D
Likes
texat 2xvacI 9300
scotland
#4
:-doh! i still have no joy in finding the correct alignment for my motorised dish on my superjack dg120 H-H.god i don't know what im doing wrong as i have the pole mounts all 100% straight the motor point non mag south and still no joy :( .Anyone got any idea's what i can do now as it looks like im going to call in a professional to do this for me but he wants £260 to do it and i think that is a rip-off lol.Oh well any idea is very welcome.
rich-sat
Likes
none
mt
#5
Hi all
I am getting a motor for my satellite installation would I be safe going for the Super Jack DG 120 or should I rather get the Stab H-H 100, for an 85cm dish?
I would rather have a robust motor than a cheaper one to be replaced in a couple of years due to corrosion/wearing out of parts.
Thanks for your help.
Likes
1,279
#6
I believe that the superjack has elevation scale on one side and Latitude on the other, if it does, then set the latitude to your latitude, if not, then the elevation scale should probably read 33 degrees.
Once you have set that up, then you need to try and find Thor 1W by moving the whole assembly on the pole and the dish elevation only, at this stage, apart from making sure that the motor is at zero, you should not be moving it via the receiver or manual buttons.
gandalfthegrey
Likes
Dreambox 800HD (clone)
Gibertini 85cm dish
4 way Diseqc switch........
linksys access point connected to Dreambox..
dublin,ireland
#7
Hi rich-sat
I have the dg120 hand book....I will pm you a scan of the elevation setup..It'll be tuesday unfortunately (back in work then) It does not show an elevation reading for lat 57..nearest is 56 and 58..
Lat 56= 34 elevation...declination=7.782
Lat 58= 32 elevation...declination=7.792
hope this helps
gandalf
