Help with technical terms please
Likes
Technomate Rciever&Dish
TM 1000D 88cm
DiSEqc H-H Motor
TM-2100A
Wiltshire UK.
#1
Could you tell me what 'satellite feeds' are exactly are they just frequencies?Also i'd like to know the difference between 'softcam keys and Aes keys'.
thank you for your help
gameboy
Ding Dang Doo
Likes
5
Scotland
#2
Satellite feeds are the 'raw' unedited pictures sent to broadcasters. These can sometime be received on home equipment.
Aes (Advanced Encryption Standard) and Softcam (Software Conditional Access Module) k*ys are the same just different names.
Likes
TM 1000D 88cm
DiSEqc H-H Motor
TM-2100A
Wiltshire UK.
#3
Thanks for the reply gameboy.ok.i now know what 'Feeds' mean but i need to know what they are.Are they frequencies?Where can i find them or learn about them?
thanks
Likes
1,279
#4
They are as Gameboy says, the raw transmissions from news gatherers and outside broadcasts, they are uplinked to a particular satellite in their unedited form for mixing by the broadcaster. They are normally transmitted as single channels taking up the whole of a transponder/frequency.
If you look down in the Transponders and Channels section, there is a thread by Satdude, which gives you some frequencies on the different satellites to check out.
Likes
TM 1000D 88cm
DiSEqc H-H Motor
TM-2100A
Wiltshire UK.
#5
Thank you rolfw for your help.
dig deep
Prince of Birthdays
Likes
208
Dream7020 and AZ Elite and a few DM800
Sweden
#6
If U find a hight speed transmission U won´t understand nothing:)
They try to keep those feeds for themselfs:cool:
