Help
D
david_egy
Likes
hi every body
i need ur help in finding a channel list file with .emt extention for eM tech E225 with hw 2.00 & sw 12.65
O
Obi-Wan
Likes
Sorry man
why do you need this extension ??
Using my JsEdit you will be able to load .jep file (program and settings from www.satnews.it) and to use all feature af your firmware (load softcam.key)
cu
O
Obi-Wan
Likes
ahhhhhh
Emt was the extension for my old program EmEdit : the development of EmEdit was stopped more than one year ago and it was replaced with JsEdit , which has the same use and more and more features .
Yuo know EmTech (now Homecast) has a lot of OEM brand as Jepssen, Kristal, Starsat and so on : most of these are supported in JsEdit
Please do not use EmEdit 'cause it is no more supported, use JsEdit !
Thanks a lot
cu
D
david_egy
Likes
hi man i couldnt find the program can u give me a direct link for downloading
