Hivion 9090x
Omar Bacha
Master key codes for all type of digital receivers
Hi Everybody:
I am new among you and shall highly appreciate if someone can provide me with Softcam and Dreamloader for my HIVION 9090X digital receiver to enable me to watch European channels including the ones for Adults. Awaiting for your prompt help and assistance.
Kind Regards,
Omar - :)
Chandrashekar
information at all satellites
Saudi ARABIA
You Can Use Loader And Dream Loader Of Sx-200ci From Satdw.com
iloya
Hi ,
I would like to know how I can update my Hivion 9090X box. Can I do it by downloading softcam.key file?
If yes then I am confused since there are so many versions of that available on the net
Please help.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I suggest you do a google search as there is a lot of interesting information re your stb
badooor
hv-9090x
isral
i need master code of hivion-9090x please if any one have
S Thomas
I want to upgrade my Hivion Satellite receiver
Ghala, Oman
Hi Everybody,
This is Sam Thomas, I would be very much obloged if anyone have Master code of Hivion 9090x please let me know.
S Thomas
Ghala, Oman
Please let me know how I can get updated software for Hivion 9090x.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
The "Report post" button is to report posts that break the forum rules, and should not be used for any other purpose.:)
If someone knew the answer to your question, I am sure they would have replied already.
bigtee
Sky; Raven 90 multi-LNB 1W,5E, 7E, 9E, 13E 16E, 19E, 28E; 60cm Triax dish on Moteck SG2100 motor; Various Receivers
Kent, UK
He could try this link: _http://hv-softwares.ifrance.com/
He could also google Pinoy Court forum.
amis
need upgrade software & cabel layout for receiver HIVION 9090x plus
Saudi Arabia
please guide me. which loader will work for HV-9090x plus receiver to load the software.if any one have pls sent it to me.
placebo87
HIVION HD-9090x Ultima
Albania, Tirana
How can I download the keys to Hivion HD9090x ultima using a usb connection with my pc or laptop?
thnx...
placebo87
Albania, Tirana
everyone is talking about garbage here man.... let me help you...just create a file _k_data.sgn in your USB wuth notepad....after doing this download a softcam open it with notepad and copy all the keys there into the file you created(using notepad)...be careful with the keys...you have to copy them carefuly and be shure that te reciever accepts them...
After doing this...put ur usb in the reciever port and go to transfer from usb menu...when you are inside the menu press "1" from the remote...and than it will ask u a question...press "Yes" and it is all done....
if you want to write the keys manualy got to menu...than go to te task that have reset to factory ..usb transfer ect..without opening any of them press "1234" from the remote and here it is....
thats all i know untill now...about HD9090x triks
saman
hd hivion 9090x upgrade
Iran
I need hd hivion 9090x upgrade software free downloadthanks
