Hornet Xtreme Firmware upgrade
adidas_jay
Downloaded the latest loaded and firmware update from www.xtreme-stb.com, connected it all up, tried updating and just got:
Target model mismatch.
Fail.
I have got the coorect firmware i presume, I don't have the PVR model, I just don't understand?!?!?!?!
Can anyone help?
W
wonderbar1
i have upgraded mine a couple of times ,are ye sure its the right software,mines xsc-520anv
waverider
waverider
Salty Tech Monster Bod
Protek 9750 HD IP, Spiderbox 9000HD. Cryptik Digital H-H Mount with1.2m Oval Dish and a box in the garage consisting of 2 obsolete STBs, various Cards and a couple of cams!
South East England
E
emanuelm
I have Hornet XSC-520anv. I want upgrade the software
R
rubio
to wonderbar1: mine is also an XSC520ANV and like emanuelm i'd like to upgrade the software (I've got S/W v12.05.03 H/W v12.03.05, loader v06.01.04, c.a. 2.1.9, info:00.02.02- ce9b), but what is the last firmware available for this model, and where can we get it? Thanks in advance
waverider
waverider
South East England
It would appear that the Xtreme sites are still down....but the Dutch sites are the most common for the firmware.
waverider
waverider
South East England
rubio said:
thanks a lot Lew
Yes thats a good link from Llew...Sorry I did not answer earlier but but been involved else where!......by the way Kaon manufacture Xtreme's if you didn't know already!
S
silvernet
Not too sure if this applies to xtreme's, but on my Kaon's, I always use Engineer Mode Loader to get around the Target Model Mismatch problem.....works fine on Kaon 570 ...I note that there is an Engineer Mode Loader for Xtreme's at the above link....It may be worth a try...
Silvernet
M
mo1965
Kaon family compatable stb which have same HW version can be upgraded using KUP2.3 by pressing spacebar on the keyboard.
Note you shold only attempt this if the HW version is the same.
