hotbird
P
pike2mike
hi all new to this hrere goes ive just brought a technsat c12 with a sky mini dish and a x cam with lodder can i get hotbird sat on it and how do i find it as i havent got a clue please thanks mike
Rob
Rob
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
Hi p2m welcome to the forum, but I'm afraid that the sky mini-dish (45cm) is to small for Hotbird.
Would be better off with a 80cm dish (although you can get quite a few channels with a 60cm, some more with a 70cm).
To get Hotbird (which has a strong signal, and is easy to find), first find Thor 1 west which is due south.
Then move the dish east 14 degrees to Hotbird at 13 east, easy peasy. :)
P
pike2mike
thanks rob the 70 cm is that the old sky dish with old lnb or can i put the lnb of the small dish on thanks
Rob
Rob
Essex
All depends on where you are, location, north, south, east or west.
The old Sky dishes were 60cm in the south, and 80cm up north.
Try your old LNB first and see what you get. If no good try the other one.
gameboy
gameboy
Ding Dang Doo
Scotland
The new LNB should fit the old dish and, as it should be universal, you will pick up the Hotbird channels.
Hotbird shouldn't be that difficult to find - once found then the fun begins!
P
pike2mike
thanks both will put other dish up tommrow will let u know what happens if ican work out 13 east form due south in the midlands
blackninja
blackninja
I got Hotbird on a 45cm sky minidish (Raven) in Cheshire last night (but no Astra 1 for some reason). Give it a try.
Rob
Rob
Essex
@blackninja, how many channels can you get with your 45cm dish.
blackninja
blackninja
On my smart centurio I seemed to get all the FTA ones - signal came up at about 65 - just above the threshold for getting a picture. Didn't sewem to get any flickers though.
Rob
Rob
Essex
According to SatcoDx they transmit 386 fta channels from Hotbird and the larger the dish the more you pick up, and also you must take into account how many channels will you lose when it rains.
Mind you on a 45cm dish I think that 65 channels is pretty good, surprised me.
blackninja
blackninja
I think the 65 relates to signal strength. Sorry should've been a bit clearer. Think I got well over a 100 channels - probably more if I can get my cam working on some of the scrambled channels (with an official card of course). It was a bit weird that I kept adjusting the dish to get Astra 19E but even though the signal strength went up to 80 none of the channels came up - but the hotbird channels still came up.
I heard Raven say that their 70cm elliptical dish acts like an ordinary 90cm dish so maybe their 45cm dish acts like a 60/70cm dish. Or maybe not.
B
bronson
stoke
At lidle 14.99 cant be bad.If they got any left.
