how deep for my pole
jpsr
1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
Mullingar, Ireland
Is a 2 foot deep by 2 foot square deep enough for a 3 inh pole for use with 96cm andrews/channel master dish.
satelliteman
Yes, a 600x600mm base sounds ok. If you can, place a couple of rods threw the base of the pole. This will prevent any future pole movement.
Depends on how high the dish is going to be above the ground, and the overall windspeeds experienced.
jpsr
Mullingar, Ireland
The pole is 6 foot in lenght. so its two foot in the ground and 4 foot over. The dish will be back against the fence and the top of the dish will be level with the top of the fence. so i wont have to worry about wind.
satelliteman
Sounds like it'll be a nice install and shouldn't experience any problem at that height. Be nice to see the pictures when your done :)
jpsr
Mullingar, Ireland
Ye ill post some pics next week.
GreenmanBelg
1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db
Humax VACI 5300
Old Panasonic Digibox
with IRL $ky sub. Coship FTA
40kms NE of Antwerp,Belgium.
We all look forward to seeing them.;););)
