how do I edit key for smart mx 01 m
kuttyantony
could you please explain how to use master code and edit key for my receiver smart mx 01 m.I want to watch discovery and animal planet chanels
DeepDiver said:
Master codes are used to acces a page on your STB MENU, where you can edit keys to open scrambled channels. The master code is used together with a procedure, and they both differ from receiver to receiver.
If you are looking for MasterCodes for your receiver, follow this link http://www.satellites.co.uk/php-bin/forum/showthread.php?t=34148 , and look at the bottom of the first post. On the same post, you will also find where to update your receiver software.
Hope it helps ;)
kuttyantony
could you please explain how to edit keys for a smart mx 01 m receiver
Have split this from the other thread as it was unrelated to your question.
