how many channels on hotbird ?
georgefromasda
expert ..... in nothing
Likes
dreambox 500s
art card
liverpool uk
#1
im kinda freaked out im only getting 300+ channels im sure i used to get more
btw when i install the full channels (downloaded) nothing happens ?
ie they dont appear (yes i put it in the channels folder )
Topper
Amo Amas Amant Admin
Likes
3,309
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
Want to count them? click here lol Perhaps you are just scanning FTA channels, certainly there are more than double that ATM
Lancelot
Likes
SS1.
36v H to H 62E - 61.5W
South central
#3
Hi george - your folder should look like this, and your scan of hotbird should produce this.
Rgds
L.:)
georgefromasda
Likes
dreambox 500s
art card
liverpool uk
#4
its odd on a zone 2 dish i got maybe 700/800 channels on hotbird , on this 1 mt i get over 300
i have used my sat meter also by eye , most channels are 100 or 80 %
im missing something out again !!!!!!!!!!!!!!!!!!!!!!!!!!
edit
693 now
Lancelot
Likes
SS1.
South central
#5
Go to http:\\www.joshyfun.cjb.net
click on 'transponders in .ini format' then get the zip file from the bottom of the page.
Unzip the file then replace the files in your transponder folder with those.
L.:)
Likes
On Hotbird with pre installed frequencies in Strong 4410 I got more that 1100 stations. Most of them coded.
Regards,
mueller
B16MCC
Dreambox Gimp & Coder
Likes
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
#7
1150 ish, using 80cm triax dish and a dreambox , northwest UK.
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
#8
1mtr dish northwest (hotbird = current)
