How many satellites on Dish TV dish
vicky_ku39
I have dish tv,dd direct dth systems and a 3.06Ghz system with 512 MB ram.
delhi,india
Sir, How Many Satellites Can I Receive From My Dishtv Antenna.i Am Located In Delhi.
Post split from original thread as it was off topic for that discussion.
afancier
Zenaga STB CD1002S, Three solid Ku band Dish. 60Cm,70cm,90cm getting Nss6 95E, Yamal201 90E, ABS1 75E, EuroBird2 26E at 26E. Disec SWITCH
Amritsar
see ku band in India........... u get the idea............ on 5 foot dish really many birds u can get..........
srei
coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card
north west india
Apart from NSS-6@95E the other easy satellite to receive on small ku antenna is insat 4b@93.5E where you can get doordarshan DTH channels.You may not have to move the dish,minor adjustment in LNB would suffice.
vicky_ku39
delhi,india
afa sir,what is the cost of a 5-ftdish antenna and how many satellite it can receive.and about yamal201@90 the dish would be straight right?
thanks for ur previous response.
afancier
Amritsar
you are in delhi....... so go to lajpat market and dish would be in between 2500 to 3500 rs........... about 90E yes........... both ku and c bands can be got......... + (95E + 93.5E ku and c)........ + 75E........83E ku and c...... 105.5E C + ku band....... 88E ku......... + 70E ku.......... 45E ku...........80E ku....108E ku...... and all these birds on one 5 foot dish at delhi........ for more detail see "ku band in India".........
Moradabad
SAT SPECIALIST INDIA
One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna
Dreambox Dm500S, DM 7025. HD Receiver,Envision,
Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs
india
@Vicky u cannot get KU beam of Yamal @90 degree on 8 feet Mesh or 6 feet solid antenna in Delhi my people have already tried Yamal @90 Ku beam in Delhi we failed to receive it on 6 feet solid prime focus antenna.
For Yamal @90 ku beam in Delhi Take a Good Quality 120 Cm Offset Dish from Lajpat Rai market .
GO TO POOJA Electronics and Ask for a Good Quality 120 CM Offset Antenna.
U will get Yamal even Hotbird also on 120-135 CM antenna in Delhi in Lajpat Rai even u will get a fiber dish.
for 2700 rs..
Bye
srei
north west india
I partly agree to you bro,but as far as Hotbird is concerned,It is not receivable until you get a 10 feet KU antenna,even then you will receive few TPs.Yamal @90 also does not provide reception of all TPs consistently in India,I miss one or two on 8 feet solid dish.
Moradabad
india
Bro we have received Hotbird around 200 Channels on 120 Cm antenna in Delhi, and Yamal @ 90 also we receuived on 120 CM Ku in Delhi....
srei
north west india
You may be right,Moradabad bro,however,you will not get all hotbird channels consistentltly,the signal may sometimes spill to fringe area but I am talking about consistent reception.
oyeindia
2 90 cm dishes, 4 set top boxes and one Hauppauge Nexus S card
Dubai, UAE
Can you tell me if you are receiving the Red Light and the MCT channels consistently on HotBird? I'm planning a move to Delhi and am wondering if I can relocate my Hotbird setup as well.
Moradabad
india
Yes Bro complete Hotbird u will get in Delhi ... Tell me ur Dish Size what u r using for HOTBIRD ?
