Robbo said:L brackets are used mainly for cheapness, I would presume.
I use them for the stand off and because they look better,nothing to do with price as customer pays that anyhow.
elevation on the motor was set to around 51.45 from what i remember, got the figure online. should i try adjusting this then? the inclination the dish plastic is around 23 , i think .....i read it has to be between 23-30 for my location.PaulR said:How did you set the elevation and inclination of the dish? Where did you get the information for what these should be set to from?
These are set by slackening off the bolts A and B in the accompanying illustration. You have to get the balance between A nd B right otherwise it'll only be right at the top (if that's where you have your reference satellite) and as the motor drives away left or right will point further and further away (up or down depending on which way it's been maladjusted) from the correct angle.
malsat said:Can you tell me how many you have to do to be a pro ?
