HB13DISH
Retired Mod
- Aug 13, 2007
- Age
- 78
- Middle East - Israel
mashster said:Adamrick!
I feel your pain, you have the same problem that I have. I am in South Africa, and have a legitimate MCA Card Version 5 Zeta, which I would also like to use in the my Dreambox 500 S as opposed to the using it in the provided MCA Decoder.
I use CCcam 2.1.0. Without some changes to the cccam.cfg file, nothing happened, I then edited the cfg file and added the same info that you had at the beginning of this thread.
Cccam showed that it was decrypting the card as in the letter showing the encryption "I" turned green, but there was no picture on my TV Screen.
I have since given up. If anyone has any solution please let me know!
MCA says that it has married the smartcard to the decoder.
And no you cannot call them and ask them for a PIN number, they do not want you to use their smartcards on any other decoder rather than their own.
Have you tried to see the entitlements using a web browser?
_http://yourboxIP:16001
Shutdown the box first, insert the card with chip face down, switch on, then select CCcam from blue button.
If nothing is shown, then you have a problem.
If there is any data, select the text and post here (just over type your card number for security reasons)
