nobbly
- Jan 1, 2000
- Age
- 51
- Not in UK
I'm trying to install a H-H crypt/stab motor but I'm having a few problems.
The instructions are not very clear,quite normal. The problem starts as I follow the instructions.
First I have to set the angle of the motor, which in my case is about 49 deg. After I set the dish angle according to the chart, about 24 deg. (Sounds easy) If I set these angles according to the instructions my dish is poiting nearly straight up and of course at that angle I will never find any satellites.
Has anybody ever fitted a crypt/stab motor like mine ?
It seams like if I set the motor at 49 deg. my dish will have to have a negative angle to be able to work.
Never had this problem with my last motor but I had to change it as it was frezzing up in the winter.
nobbly :+
nobbly :+
