How to keep pole level whilst concrete sets?
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Hiya,
Bought a 3 meter pole to concrete into the earth, I have a spirit level to check it's level but I question how I am to keep it from moving whilst the concrete sets? The pole is reasonably heavy.
Archived-1
Persona non grata
uk
prop it with bricks inside the hole before you concrete, then i would use the quick setting post mix, make sure to check for plumb both ways, ie if you check its plumb a 6 oclock you also need to check 9 or 3 oclock, just fine tune just before it sets solid 5/10 mins its gone off,
but dont fix the dish for at least 12 hours after,
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
use postfix,
settles nice and quickly
wod
yorkshire
Use a post level and use some rope tied to a fence or something to keep it upright ?
Simple answer is don't fix the pole directly in the concrete, make it adjustable.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Yes, adjustable like this. Black part goes to concrete and pole itself is attached and leveled after.
aceb
Prof Tuner 7301 /
Sussex
Here is how I did it for my 1.5m.
P.S. all the dust underneath is from going past with the cultivator, and not due to concrete failure.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Thanks for all the options. I really like the idea of the end result just being four bolts sticking out the concrete. Will have to take a think. If I go for that I'll have bought a 3 meter pipe for nothing! Bah. But then if I do try concrete the pole in, something I've never done, I can see me doing it wrong. :/ Id never be able to relax in those 12 hours from pouring to mounting the dish to see if it's level.
Retired human
I've concreted the pole before and it worked out OK. I just had a long piece of plank with a nail at the top holding it in place.
pgh13
Midlands UK
Can't you just get the missus to hold it til it sets? :-rofl2
RimaNTSS
N-E from Riga
At the and of the day, it is not so necessary to get your primary pole so dead-plumb-vertical. Anyway on that pole you will mount antenna which has additional ways to have it vertical. So, basically it dos not matter how vertical is your pole you are cement in the ground. IMHO.
Possible to compensate a bit on a DiSEqC 1.2 setup, but not with USALS. Best thing is always make it adjustable or get it straight in the first place, not try to compensate later.
Piltdownpaul
No.1 Spike Milligan Fan
Nice bit of engineering there, a novel way of getting it crack on. :-respekt
RimaNTSS
N-E from Riga
Not arguing here. I also prefer primary pole vertical, but in case it is not than almost all polarmounts have their own adjustment bolts (picture). For Simple offset antennas pole verticality does not really matter. For T-90 installation is also possible to tune it without perfect vertical pole. For USALS, I think, pretty easy to make small device - 1/2meter piece of pipe with 6 welded nuts.
Piltdownpaul
Rima, do you put a second nut on the adjusting bolts and tighten up to the captive ones welded to the pole or dont you need to?
RimaNTSS
N-E from Riga
There are only 6 welded nuts and 6 bolts, no need for additional nuts.
You just tighten them up on the pole. They're a terrible mount because when you loosen them the dish loses alignment. Absolute nightmare to adjust.
Piltdownpaul
But some bolts could be kept where they were before dismantling if the bolts were locked by an nut against the welded one. Then you would only have to undo a few bolts to dismantle.
RimaNTSS
N-E from Riga
Yes, you are right, in case of finding true South and moving this around the pole you need to do all the adjustments of antenna again. To prevent that, I have special device, so with 6 bolts make device vertical and than move upper part very gently left or right.
