How to monitor signal strength with a PC Freeview Card
gov400
gov400
Likes
Dreambox 7020s
Gibertini OP120 Dish
STAB HH120 MOTOR
London
#1
Hi guys
I purchased recently a Hi Gain Tv aerial and i am gonna go fit it on my roof. The problem is how can i be sure i fit it in the right direction. Is there a signal monitoring program for the pc?
Likes
1,291
#2
There is if you have a DVB-T PCI card, but otherwise it is down to comparrison with the direction of surrounding aerials.
gov400
gov400
Likes
Dreambox 7020s
STAB HH120 MOTOR
London
#3
i have a dvb-t device, Twinhan Der T+A PCi. What program do i use
Likes
1,291
#4
I think that most of them have a signal strength bar, but have no way of seeing at the moment, as I am abroad with my laptop.
gov400
gov400
Likes
Dreambox 7020s
STAB HH120 MOTOR
London
#5
ok thanks. Hope others will help me
S
spiney
Likes
Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
Midlands
#6
see my freeview aerial guide, further below, which is generally applicable, principles are exactly the same:
www.satellites.co.uk/php-bin/forum/showthread.php?t=43646
I don't have a PC dvb-t (freeview) card, but you need the menu selection that shows signal strength/quality, across the digital multiplexes and per multiplex. Find the lowest strength one, then on that adjust aerial for highest "signal quality" (not necessarily the highest strength!). That should be the best reception, if you're in reception range and there's no special problems.
gov400
gov400
Likes
Dreambox 7020s
STAB HH120 MOTOR
London
#7
spiney i read it. I want to no would i get a good signal for freeview if i stick my aerial on my extension roof (half the height of my house). Its a powerful hi gain aerial.
Likes
1,291
#8
It will depend entirely on what is in between your aerial and the transmitter.
gov400
gov400
Likes
Dreambox 7020s
STAB HH120 MOTOR
London
#9
ok thanks will give it a go 2day
