Thank you for your attention on this matter. Well, we have IPTV solution with Amino 110. Unfortunately is too expensive for our customers. So we start to look for alternative solution. I found out that the processor of DM500 and Amino are the same exactly model. So, thinking in this way perhaps we can use it.
The picture is like this:
1. We are catching the SAT stream via QPSK inputs and VLC based on Linux is streaming it to the STB (Amino in this case) via UDP at specific port. Channel list looking like this: http://192.168.12.6/wwwvlc/vlc-192.168.17.11?stop=no&action=1230>
where 192.168.17.11 is IP address of STB and 1230 is the port we are streaming this particular channel. Next channel will be 1231 for example. So, when VLC get this URL it start streaming to the STB.
2. DM500 can be used as is with http but not udp - someone have to write a program to be used UDP. At the moment we tested that the stream can be viewed at DM500 (http way) but we can not managed the channel list - there is not plug-in ready made
So we have 2 major problems to solve with DM500: 1. with the channel list and 2 if we can make DM500 to handle UDP stream but not http.
What is your comments?
