Increase Multi-sat dish size
JohnC
Pioneer PDP- LX5090 50"TV
2x Samsung 50" TV
Sony RDRHXD870 DVD/HDD Recorder
Sony RDRHDX950 DVD/HDD Recorder
Humax Foxsat HD
Technomate TM-5402HD piggy-backed to a
Technomate 5500 CI Dap receiver.
Technomate TM5400C-usb connected also to 1.2 metre mo
Multi-sat enthusiast in the Heart of England since 1993....
Guys
I would like to increase the dish size of my 1.2 mtre prime focus dish without buying a new postioner and stand.
What I would like to know is if I bolted a larger dish (say a 1.8 or 2 mtre) in place of my existing dish would the tracking work the same and are there any other problems or setbacks to consider before going ahead with the project??
Im confident about the support and positioner being strong enough, the later being made of half inch casting.
Thanks in advance John
If the mount is the same, then you should be able to switch over, but you will need to fine tune or more..
As Rolf says, the larger the dish size, the more precise the focussing of the signal becomes.
If you are drilling the new surface to bolt on the old mount, the holes would have to be in the same position around the centre of the dish to ensure the signal is received from the same position in space.
Also the feed and the distance of each of the arms (3 or 4 on a prime focus dish) make a lot of difference to the final direction signals can be received from .
stevo
dreamboxhd 800 pvr
2 x dreambox 500s
globalstar-m6 free to air
1 metre dish
80cm dish
60 cm dish
all via diqsec switch.
england
JohnC said:
Guys
why dont you buy a dish like this my friendO-Ha O-Ha O-Ha
Ahh yes, that was the Mk1 Sky minidish, fortunately Sky persuaded S.E.S Astra to increase the satellite output, so that they could reduce the size slightly. :)
JohnC
2x Samsung 50" TV
Humax Foxsat HD
Darn it......
I would have to move the greenhouse......!!!
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
Don't you mean the house!
JohnC
2x Samsung 50" TV
Humax Foxsat HD
Its a real "must have"...!!
So the house will have to go...!!!
I could sit watching my TV inside the LNB then and I would be happy as larry...!!
