Interstar DSR 8005 plus inserting password problem
gorila22
Hello
I have a problem with this receiver. When I want to put in the code for "instalation" (factory default pin is 0000) it does not allow to insert the 4th digit. Anyone else had this problem??? In general how is this receiver? good or bad. i paid 200EUR.
simon
gorila22
oops. Basically get the right code and then it works...if u start with wrong digits then it does not allow u to enter the 4th
sorry
Ihsan1407
You need to reset it to the default setting, then you can type 0000
